21602 讨论
cyclone II : dual port dual clock memory possible?
名誉分销商 II
2,004 次查看
There is any workaround to this problem?
Error: M4K memory block WYSIWYG primitive "vram8k:vram8k_inst|altsyncram:altsyncram_component|altsyncram_3s62:auto_generated|ram_block1a0" utilizes the dual-port dual-clock mode. However, this mode is not supported in Cyclone II device family in this version fo Quartus...
I am using Quartus 7.2SP1 Web edition.
I am implementing a soc, and would like to have 2 ports, dual clock video memory.
Roni
0 项奖励
4 回复数
名誉分销商 II
988 次查看
The error might be related to the M4K issue in the Cyclone II errata sheet. Check the errata sheet to see whether it is OK for your design to use a setting that will let Quartus implement the memory.
0 项奖励
名誉分销商 II
988 次查看
--- Quote Start ---
Roni
--- Quote End ---
I got the same problem, anybody knows how to make it work ? thanks
0 项奖励
名誉分销商 II
988 次查看
You have to add a default parameter in Analysis & Synthesis Settings, as described in the Cyclone II Errata Sheet (shown as respective tcl command)
--- Quote Start ---
set_parameter -name CYCLONEII_SAFE_WRITE "\"RESTRUCTURE\""
--- Quote End ---
The memory consumption is however doubled by this workaround. For known fixed devices, another setting exists.
0 项奖励
名誉分销商 II
988 次查看
--- Quote Start ---
--- Quote End ---
You're the man. It does work, thanks a lot.
0 项奖励
回复
