hello to all,
i am a new member of this forum. i have a problem and i hope that you can will be help me! i have a cyclone II ep2c35. how can i do for program this chip? can you help me? in the past i had a de2 development kit and i used the usb blaster but i wrote the binary file in ram so when i removed the power my application was lost and i had reprogramming the chip!!! thank you for all. stefaniaLink Copied
Take a look at the configuration chapter in volume 2 of the Cyclone II handbook. You will need either a download cable or a configuration device of some sort EPC, flash with controller, flash with microprocessor. Download cable like USB Blaster can be used to program in Passive Serial mode and also JTAG if the device is in a JTAG chain. I think you will find the information you are looking for in this chapter linked below.
http://www.altera.com/literature/hb/cyc2/cyc2_cii51013.pdf (http://www.altera.com/literature/hb/cyc2/cyc2_cii51013.pdf)- Mark as New
