21611 Discussions
cyclone4 ibis models for OCT outputs wrong?
Hi to all.
I am using quartus prime 16.1.2 to generate the ibis model I / O to do the signal integrity.
I have a 3v LVTTL output line (fFPGA) that I have to be connected to an external chip.
In "pin planner" if I disable a series termination is generated a ibis model with 27.9 ohms output driver impedance
If i put series 25 ohm without calibration is generated a ibis model with with 11.7 ohms output driver impedance.
If i put series 50 ohm without calibration is generated a ibis model with with 11.7 ohms output driver impedance also.
where am I wrong?
I insert the simulations that confirm what I said:
BEst regards.
