Programmable Devices
21602 Discussions
dangling port&logic
hello .
i wrote a program, then i compile it. and it is compiled properly.
this program has 4 entity. after compliation, i could see entity-4 in RTL viewer but there isn't in technology map viewer completely. further more it hasn't any output. when i checked the "connectivity checks" it reveals that the following info:
Connected to dangling logic. Logic that only feeds a dangling port will be removed.
thank you.
hello.
I could find the problem. i inadvertently commented one of control outputs then the next entity that works with it was dangled.
