hello, could someone explain me this following code? i have found it in a demo application but with no Comments. thank you
module sigdetect( oTD_Stable, iTD_VS, iTD_HS, iRST_N ); input iTD_VS; input iTD_HS; input iRST_N; output oTD_Stable; reg TD_Stable; reg Pre_VS; reg [7:0] Stable_Cont; assign oTD_Stable = TD_Stable; always@(posedge iTD_HS or negedge iRST_N) begin if(!iRST_N) begin TD_Stable <= 1'b0; Stable_Cont <= 4'h0; Pre_VS <= 1'b0; end else begin Pre_VS <= iTD_VS; if(!iTD_VS) Stable_Cont <= Stable_Cont+1'b1; else Stable_Cont <= 0; if({Pre_VS,iTD_VS}==2'b01) begin if(Stable_Cont==9) TD_Stable <= 1'b1; else TD_Stable <= 1'b0; end end endLink Copied
--- Quote Start --- hello, could someone explain me this following code? i have found it in a demo application but with no Comments. thank you module sigdetect( oTD_Stable, iTD_VS, iTD_HS, iRST_N ); input iTD_VS; input iTD_HS; input iRST_N; output oTD_Stable; reg TD_Stable; reg Pre_VS; reg [7:0] Stable_Cont; assign oTD_Stable = TD_Stable; always@(posedge iTD_HS or negedge iRST_N) begin if(!iRST_N) begin TD_Stable <= 1'b0; Stable_Cont <= 4'h0; Pre_VS <= 1'b0; end else begin Pre_VS <= iTD_VS; if(!iTD_VS) Stable_Cont <= Stable_Cont+1'b1; else Stable_Cont <= 0; if({Pre_VS,iTD_VS}==2'b01) begin if(Stable_Cont==9) TD_Stable <= 1'b1; else TD_Stable <= 1'b0; end end end --- Quote End ---
module sigdetect (oTD_Stable, iTD_VS, iTD_HS, iRST_N);
input iTD_VS;
input iTD_HS;
input iRST_N;
output oTD_Stable;
reg TD_Stable;
reg Pre_VS;
reg Stable_Cont;
always @ (posedge iTD_HS or negedge iRST_N)
begin if (!iRST_N)
begin //all reset
TD_Stable <= 1 'b0;
Stable_Cont <= 4' h0;
Pre_VS <= 1 'b0;
end
else
begin //this is for each horisontal syno impulse
Pre_VS <= iTD_VS;
if(!iTD_VS)Stable_Cont <= Stable_Cont+1' b1; // blank time. Old frame is finish. But new frame is not begun. count HS singal pulses during blank time.
else Stable_Cont <= 0;// draw frame. do nothing
if ({Pre_VS, iTD_VS} == 2 'b01)// new frame is begin.
begin
if(Stable_Cont==9) TD_Stable <= 1' b1; // if during blank time been 9 pulses HS the signal is stable.
else TD_Stable <= 1 'b0; // signal not stable.
end
end
end
blank time os "back moving beam". I don't know how to in english.
--- Quote Start --- blank time is http://en.wikipedia.org/wiki/vertical_blanking_interval Sorry for my English. --- Quote End --- thank you for your Answer, aber i can't understand why 9 pulse is using
--- Quote Start --- thank you for your Answer, aber i can't understand why 9 pulse is using --- Quote End --- It's you video signal parameter. You V-blank duration is 9 horizontal sync pulses.
--- Quote Start --- It's you video signal parameter. You V-blank duration is 9 horizontal sync pulses. --- Quote End --- i cannot find this info that the V-blank is 9 horizontal sync pulses, can you give me more details...thanks
--- Quote Start --- i cannot find this info that the V-blank is 9 horizontal sync pulses, can you give me more details...thanks --- Quote End --- It's depend on video signal. Different video signal have different parameter. The exactly 9 pulses looks very strange. Usually for video signal specified duration of V-blank, H-blank. And not exactly. You can find parameters for PAL or SECAM or VGA.
