21615 Discussions
emac0 through FPGA
I have to setup emac0 RGMII through FPGA. I read the https://rocketboards.org/foswiki/view/projects/cyclonevrgmiiexampledesign example and build my system similarly.
Linux shows the link is up:
dmesg:
libphy: stmmac-0:04 - Link is Up - 1000/Full
libphy: stmmac-1:05 - Link is Up - 1000/Full
I know this message is related to the MDIO-IF.
However ifconfig shows
eth0 Link encap:Ethernet HWaddr 00:4E:8B:C3:E5:9B
inet addr:192.168.1.110 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::24e:8bff:fec3:e59b/64 Scope:Link
inet6 addr: 2a02:810a:c0:17c4:24e:8bff:fec3:e59b/64 Scope:Global
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:8685 errors:0 dropped:0 overruns:0 frame:0
TX packets:2687 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1275057 (1.2 MiB) TX bytes:406534 (397.0 KiB)
Interrupt:152 Base address:0xc000
eth1 Link encap:Ethernet HWaddr 00:4E:8B:C3:E5:9C
inet addr:192.168.2.108 Bcast:192.168.2.255 Mask:255.255.255.0
inet6 addr: fe80::24e:8bff:fec3:e59c/64 Scope:Link
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:705 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:198084 (193.4 KiB)
Interrupt:147 Base address:0x8000
I'm sure it depends on hardware, then I exchange eth0 and eth1 the other doesn't work.
Furthermore I found, the Tx clock from the RGMII to GMII adapter is 2.5 MHz and consistently the Tx clock from the splitter to the HPS too. The emac0_gtx_clk = 125 MHz. But the HPS outputs only data on emac0_phy_txd_o [3.0]. That means Tx uses only 4 bits.
Why only 4 bits are used? Why outputs the RGMI2GMII adapter only 2.5 MHz.
Any hints?
Thanks Tom
