21611 Discussions
enable/disable interrupt
I am porting a small kernel from avr to nios2 using a DE2 board. I have tried to modify the enable and disable interrupt macro like the follow:
# define DISABLE_INTERRUPTS {
asm volatile (
"addi r27, r27, -4 \n\t"
"stw r3, 0(r27) \n\t"
"stw r2, 0(r27) \n\t"
"movhi r2, 0xFF00 \n\t"
"subi r2, r2, 2 \n\t"
"rdctl r3, ctl0 \n\t"
"and r3, r3, r2 \n\t"
"wrctl ctl0, r3 \n\t"
"ldw r2, 0(r27) \n\t"
"addi r27, r27, 4 \n\t"
"ldw r3, 0(r27) \n\t"
"addi r27, r27, 4 " );
# define ENABLE_INTERRUPTS {
asm volatile (
"ori r3, r3, 1 \n\t"
When I try to debug using the hardware, the status register can not be correctly set. But when I use the instruction set simulator, it works fine.
Can someone give me some hint.
with regards,
Wei
Why don't you use altera's library irq enable and disable?
Hi aprado,
--- Quote Start ---
--- Quote End ---
I have looked into the provided one.
The alt_irq_enable_all need a context, which force me the modify other kernel code.
you can pass null as the context i think
--- Quote Start ---
--- Quote End ---
I will try that.
Context is useful when calling irq enable all to restore interrupt conditions present before calling irq disable all!
