Programmable Devices
21611 Discussions
external clamping diode for Cyclone 3
During implementation I get the following fitter warning:
Warning: Following 1 pins must use external clamping diodes.
Info: Pin Nios2Processor:\b_uP_MemInt_I2C:i_Nios2Processor|epcs_controller:the_epcs_controller|tornado_epcs_controller_atom:the_tornado_epcs_controller_atom|the_tornado_spiblock~ALTERA_DATA0 uses I/O standard 2.5 V at N7
My design uses an EPCS flash (powered @ 3V3) and it uses pin N7, which is situated in a 3.3V bank.
This is confusing:
- The handbook uses a clamping diode to Vccio, in my case that is 3.3V
- Quartus tells me to add a clamping diode, it doesn't specify to which voltage but I guess that it is the 2V5
- Is the input buffer for the data0 pin powered by Vccio (3V3) or by Vcca (2V5) ?
Can you clarify this?
thanks and best regards,
Karel D
When you use a configuration circuit suggested in the handbook, you should simply ignore the said warnings.
