21592 Discussions
fixed delay chain & periphery clock
I am trying to implement a fixed delay on CLK path.
Basically the CLK is DDR DQS to my DUT.
I have used LCELL logic to implement the delay I require but this delay is changing with each PAR run.
I need some logic somewhat like a Regional Buffer of Xilinx (we used this successfully for above experiment)
Regional Buffer -- Delay -- Regional Buffer
So the delay is fixed and always lies between the Buffers only.
Can someone guide me on How & What should i follow on Altera Devices (We are using Stratix-4)
Won't using the DQS pins and ALTDQS function be better?
If that doesn't work out, you can try to fix the LCELL's placement. But even so, it's subject to PVT variations.
