21596 Discussions
flash memory issue
Hello everyone,
I have a Altera max10
I have a flash memory issue. When I download a program in FPGA, then I power off then power on. The program isn't keep in memory.
I use the same software, but with a kit max10. The memory works. So that's mean I have a hardware issue. But when I check some pins like
-CONF_DONE. It has a pull up, so no problem.
-nSTATUS should be connect to a pull up. But it's put in a ground. But normally no impact.
So Except CONF_DONE nSTATUS nConfig. What else pins should I verify?
Thanks a lot
