21611 Discussions
format conversion
how to convert from std logic vector to integer?
and
how to convert from sfixed to std logic vector ??
:confused::confused::confused:
Loads of good info here...
www.synthworks.com/papers/vhdl_math_tricks_mapld_2003.pdf
(Hope its OK to post links here, if not I will delete if requested :)
Top tip....
Alwyas use the package
use ieee.numeric_std.all
for all new designs.
For integer to std_logic_vector to you need to convert to unsigned (or signed) first
signal A_slv : std_logic_vector (7 downto 0) ;
signal Unsigned_int : integer range 0 to 255 ;
Unsigned_int <= to_integer( unsigned( A_slv ));
Good luck
vernmid thanks alot for your help!!!!!!! rili thanks alot!!! i will try it out!!!
