21615 Discussions
frequency divider
i want ot create frequency divider which devide the frequency by 50 000 000 (so with 50 MHz clock i want ot reach 1 HZ (T=1s))
can i use this code:
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity counter is port (CLK, RST :in std_logic; devided_clk : out std_logic; Q :out std_logic_vector(16 downto 0) ) ; end counter; architecture beh of counter is signal QL : std_logic_vector (16 downto 0); begin process(CLK, RST ) begin if (CLK'event and CLK = '1') then if RST='1' then QL <= "00000000000000000"; devided_clk<= '0'; else if (QL = "11101110011010110010100000000") then QL <= "00000000000000000"; devided_clk <= '1'; else devided_clk <= '0'; QL <= QL+1; end if; end if; end if; end process; Q <= QL; end beh;
process(CLK, RST) begin if RST then QL <= "11101110011010110010100000000"; devided_clk<= '0'; elseif (CLK'event and CLK = '1') then if QL == "00000000000000000" then // comparison with zero is cheaper QL <= "11101110011010110010100000000"; // half count reached, reload devided_clk <= ~devided_clk; // toggle output else QL <= QL - 1; // decrement instead of increment end if; end if; end process;
This code is better and simpler. Oh, and do not forget Altera likes async resets (unlike Xilinx). But you should sync the reset signal (it should be the output of a CLK clocked register).
--- Quote Start ---
Oh, and do not forget Altera likes async resets.
--- Quote End ---
It's suggested by the FPGA core architecture, available without requiring additional LE input terms, but you are free to prefer synchronous resets in your designs.
Some complex Altera MegaFunctions only provide a synchronous reset - without an explicite specification in the user manual.
so with amilcar's code the time between two positive jumps (0->1) will be 1 sec ?
I did not calculate the constant, I just reused your value.
BTW you can replace "000000000" with "(others => '0')"
And you can write your constant Like this:
constant CLK_PERIOD_NS = 20; -- CLK period in [ns] units
constant DESIRED_PERIOD_NS = 1000000000; -- desired period in [ns] units
constant TIMER_RELOAD = DESIRED_PERIOD_NS/CLK_PERIOD/2-1;
And then just replace
"11101110011010110010100000000" with TIMER_RELOAD
so i think in amilcar example the half time must be 25 000 000 (i want from 50 MHz to reach 1 hz ) but i do not have fpga module and i do not know how to simulate frequency devision ?
any tips ?
