21615 Discussions
get problem while compile the qts_fmc demo of C10GFP
LTN
The board is Cyclone 10 GX Development kit,  I download the Kit Collateral (zip), and compile the qts_fmc demo with Quartus Pro 17.1 per its required, I didn't do any change to the demo, but I get error, you can check the attached compile_error.txt for the error detail.
Could you help to check what's the problem and how to fix it?
PS:I see someone had met the same problem when compiling the qts_fmc demo,I met it too.Then I solve it by downloading and installing a10 device database file.So this time could you help me?
Deshi_Intel
HI,
The Quartus synthesis error was due to broken QSYS design connection link.
The solution is to regenerate the QSYS design again then you will be able to recompile the design again. I have shared the successful compilation design QAR file for your reference.
dlim
Deshi_Intel
Attached is the quartus synthesis error fixed design
Deshi_Intel
HI,
dlim
