Hello everybody
I'm working with the short time Fourier transform (STFT), I would like to implement and show the results on a screen using VGA port, but I do not have idea how to do it. I would appreciate your help... thanks.Link Copied
What do you need help with? you will need a VGA controller for a start....
I want to implement the STFT on the FPGA (stratix ii) with quartus (if someone have an example) and I would like to show the result by using the VGA port.
Best regards- Mark as New
Then I suggest at least coding (or finding) a VGA controller, and the STFT.
How can I implement the short time fourier transform on FPGA?
With an HDL - either VHDL or verilog.
