21595 Discussions
has anyone observed a programmer crash when S10 transceiver tile configured?
Eugene_G_Intel
has anyone observed any Stratix 10 issues during configuration when transceiver tiles are used? Our observation is If left unused, programming will be successful.
Only 1 of 4 transceiver tiles cause this problem. When one of 4 transceiver tiles are configured even with the simplest design, it will crash the programmer at 5% with an error log. Configuring other tiles and skipping the suspect one will make configuration pass as well.
This is from new board power up checking. Only 1 device is behaving this way but before we rule out the device, does anyone know if a signal (data or clock), or power level or connection problem can cause this behavior to the programmer?
YuanLi_S_Intel
