21607 Discussions
help:how to generate netlist
Is there any shortcut to generate netlist in quartus ? if not, how to generate my custormer board netlist?
Which version of Quartus you are using? I guess it was required in older versions
--- Quote Start ---
--- Quote End ---
version 6.0. in version 5.0,i can add board in command shell,but it's no use in version 6.0. it's need one netlist file to describle your board. So i want to kown how to generate the file.
First of all I suggest you to download the latest QuartusII version from the web. Then compile your project and the netlist is automatically generated. What is your netlist required for?
--- Quote Start ---
--- Quote End ---
I need netlist to add customer dev board to SOPC,because now i'm in using flash programming.
In version 6.0 i can't add board from command shell. So i add my board in sopc gui file->new board description,but it's need one netlist file.
After you have upgraded your Quartus II version, you have to go to the Assignment-Settings menu and the relevant window will open up. Then you have to set the appropriate Tools in the EDA Tools window. Th netlists will be generated according to the settings that you will use in this window.
Better you download lates altera tool suite that is version 8.0 with Service Pack 1. In this version you will not need to create net list to download anything to flash using flash-programmer utility either through GUI or command.
thanks . i'll take a try.
