21602 Discussions
help! msel select, cyclone iii
hi,all.
i use the ep3c10e144c8n and epcs16.
i set the msel scheme to 100.
VCCIO of the banks in which the configuration pins reside is 3.3V.
the EPCS16 used is powered by 3.3V
according to the quartus ii, i can download the programme to the ecps. But it can't configure the fpga.
and i also want to know the mean of "Configuration Voltage Standard" in the datasheet. The power of the epcs and VCCIO of the banks in which the configuration pins ?
MSEL pins must be connected to 2.5V. NOT 3.3V
The other pins are 3.3V
