21602 Discussions
help! problem with a program
begin
state <=# 1 stop;
shift_start <=# 1 1'b1;
index <=# 1 index + 2'b01;
case (index)
2'b00: sig_num <=# 1 4'b1011;
2'b01: sig_num <=# 1 4'b1101;
2'b10: sig_num <=# 1 4'b1110;
2'b11: sig_num <=# 1 4'b0111;
endcase
end
this segment program above have a doubt with me.when it runs ,if the index=00, the sig_num is 4'b0111; but i think it should be 4'b1011.
can someone tells me why?
Now, index == 2'b11, the value in port 'd' of sig_num reg(or d-flip-flop) is 4'd0111
Then an active edge of clock comes,
index turns to 2'b00,
SIMULTANEOUSLY, sig_num turns to 4'b0111(for 'd' to 'q').
HDL describes hardware structure, all statements in a block, especially non-blocking assignments in synchronious block are taking effects simultaneously.
