21611 Discussions
help: reconfiguration,error!
hello,
my system includes cyclone1, epcs4, ext_flash,and so on. configuration data is stored in epcs, and nios program is stored in ext_flash. now, i compiled two projects, and they were only small differences in their *.flash format file, and i found the differences. i downloaded one .flash file into epcs, and in nios program i changed the different configuration data between the two .flash file. and then re_Por, i found fpga run by mistake. i don't know why. can anybody help? thanks!
I could not get you properly, but you should look at reset location given for NIOS II in your design from where it starts executing program on POR.
hi,
this problem has been resolved.
when i try to modify some bytes in one sector/block, the fpga run by mistake, but when i wrote the whole block including the different bytes, it's ok! i don't know why.
when it run by mistake(under modifying the different bytes), i downloaded an sof file into fpga(not epcs) in quartus, and run nios ii, i read the whole block, i found the whole block was filled with "0xFF".
