Programmable Devices
21611 Discussions
help with altshift_taps problem!!
Hi!
when i use some ip cores with quartus megawizard plug-in manager,such as lpm_divide, some altshift_taps will automaticly added on my project。the problem is the altshift_taps are implemented with some M9Ks,but they use only a few bits, so i think it is a waste for M9Ks。 what should i do to make the altshift_taps implement with LC elements instead of M9Ks??? can i change some settings of quartus ii software?
--- Quote Start ---
Hi!
--- Quote End ---
I assume you choose the shift register under "Memory Compiler" (shift-register Ram-based). In this case it could be only implemented with the RAM resources of the FPGA. Which kind of RAM's you could use depends on the FPGA type.
If you would like a register implemetation you can try the shift register under "Storage" (LPM_SHIFTREG).
Kind regards
GPK
