21615 Discussions
here are no Nios II CPUs
Hi, I get the following warning when I attempt to debug an application on the target:
There are no Nios II CPUs with debug modules available which match the values
specified. Please check that your PLD is correctly configured, downloading a
new SOF file if necessary.
I've previously debuged this application without issue, can any one point me in the right direction?
regards,
Dave
It looks like the FPGA isn't configured properly. Check that you uploaded the correct .sof image to the FPGA.
thanks Daixiwen that seems to of solved it, just my SOPC_BUILDER_PATH problem on another machine to resolve and I'm back up and running!
