how are realtime applications ???? the deffirence when simulate and implement in hardwave
Can you please re-phrase the question?
Real time apps are ones that work on real time data (like video). They can be simulated like any other application (you provide a set of data, and check to see if the results are as yo expected). Simultions will not run in real time.- Mark as New
--- Quote Start --- Can you please re-phrase the question? Real time apps are ones that work on real time data (like video). They can be simulated like any other application (you provide a set of data, and check to see if the results are as yo expected). Simultions will not run in real time. --- Quote End --- thanks,my bad,my english is not quite
