hi ,
now i use cyclone iv fpga,EP4CE115F29C8. i want to know which clock can it run, in my system i give 162Mhz, and system work well ,if it's too high?Link Copied
Providing you feed your clock into a dedicated clock input, you will probably be able to run your logic at that frequency in that device. I say 'probably' as you will need to be very careful with your logic design. Poorly designed logic will definitely not run at that frequency in that device.
