21602 Discussions
how to avoid this warning?
Recently,i am working with EPM570T10I,program with Verilog hdl.
When i compiler the code,but there is a warning in Quartus II:
Warning: Found 1 node(s) in clock paths which may be acting as ripple and/or gated clocks -- node(s) analyzed as buffer(s) resulting in clock skew.
Info: Detected ripple clock "flg_oc_1" as buffer
But,the signal "flg_oc_1" is not a clock in my design ,it is just a pulse signal。
How should i do to avoid the warning?
THX!!!
--- Quote Start ---
THX!!!
--- Quote End ---
if you really would to get rid of the warning you can use the assignment editor:
Assignments -> Assignments Editor -> ( fill in node name in the "to" column) -> choose assignment "not a clock". Don't forget to set the Value to "on".
--- Quote Start ---
--- Quote End ---
THX for your help first.The method you mentioned above i have tried,but the
warning is still,and another warning happens:
Warning: Found invalid timing assignments -- see Ignored Timing Assignments report for details。
No timing path applicable to specified destination。
By the way,the signal “flg_oc_1” is a internal variable,not a IO。
--- Quote Start ---
--- Quote End ---
hi,
it looks like that you have a clock setting defined for this signal (?), but you defined now that it is not clock. The constraint is no longer applicable.
hi,i do not define any setting excepting for the setting "not a clock".
The code:
module over_current_check (
clk_1m,
over_current_signal,
rst_n,
flg_block_drv,
flg_over_current
parameter CNT_FORTY = 6'b101_000,
CNT_TWO_THOUSAND = 15'b100_111_000_100_000;
input wire clk_1m;
input wire over_current_signal;
input wire rst_n;
output wire flg_block_drv; //over current,disable drive output 20ms
output wire flg_over_current;
wire flg_oc_2;
reg flg_oc_1; //if the over_current_signal keep low for 40us,flg_oc_1 keep high level 1us
reg out_feed;
reg flg_block_drive_1; //if flg_oc_1 is high,flg_block_drive_1 keep high for 20ms
reg [5:0] cnt_40;
reg [14:0] cnt_20000;
always @ (posedge clk_1m)
begin
if (!rst_n)
begin
cnt_40 <= 6'b000000;
flg_oc_1 <= 1'b0;
end
else
begin
if (!over_current_signal)
begin
if (cnt_40 == CNT_FORTY)
begin
flg_oc_1 <= 1'b1;
end
else
begin
cnt_40 <= cnt_40 + 6'b000001;
flg_oc_1 <= 1'b0;
end
end
else
begin
flg_oc_1 <= 1'b0;
end
end
end
assign flg_oc_2 = flg_oc_1;
always @ (posedge out_feed or posedge flg_oc_2)
begin
if (out_feed)
begin
flg_block_drive_1 <= 1'b0;
end
else if (flg_oc_2)
begin
flg_block_drive_1 <= 1'b1;
end
end
begin
if (!flg_block_drive_1)
begin
cnt_20000 <= 15'b000_000_000_000_000;
out_feed <= 1'b0;
end
else if (flg_block_drive_1)
begin
if (cnt_20000 == CNT_TWO_THOUSAND)
begin
out_feed <= 1'b1;
cnt_20000 <= 15'b000000000000000;
end
else
begin
cnt_20000 <= cnt_20000 + 15'b000000000000001;
end
end
end
assign flg_block_drv = flg_block_drive_1;
assign flg_over_current = flg_oc_1;
endmodule
--- Quote Start ---
The code:
clk_1m,
rst_n,
flg_block_drv,
flg_over_current
input wire clk_1m;
input wire rst_n;
wire flg_oc_2;
reg out_feed;
reg [5:0] cnt_40;
begin
if (!rst_n)
begin
flg_oc_1 <= 1'b0;
end
else
begin
begin
begin
flg_oc_1 <= 1'b1;
end
else
begin
flg_oc_1 <= 1'b0;
end
end
else
begin
flg_oc_1 <= 1'b0;
end
end
end
begin
if (out_feed)
begin
end
else if (flg_oc_2)
begin
end
end
begin
begin
out_feed <= 1'b0;
end
begin
begin
out_feed <= 1'b1;
end
else
begin
end
end
end
endmodule
--- Quote End ---
you are right , the "not a clock" is only valid for I/O's. It is not valid for internal nodes, therefore the additional warning.
In your code you have tyhe following stuctures
begin
if (out_feed)
begin
end
else if (flg_oc_2)
begin
end
end
You may be assuming that flg_oc_2 is just a strobe but in fact the coding style infers a clock!
The above code will infer a FlipFlop for flg_block_drive_1 with flg_oc_2 as a clock input.
So the warning is correct.
Hope this helps
--- Quote Start ---
begin
if (out_feed)
begin
end
else if (flg_oc_2)
begin
end
end
Hope this helps
--- Quote End ---
After looking into the RTL view of the Quartus project I found, that the output of the register is driving the clock input of another FF. Quartus has to treat this signal as a clock. The warning is correct.
--- Quote Start ---
--- Quote End ---
yeah&#65292;you are right,may i ignore the warning&#65311;The waveform of the simulation is that what i need.
--- Quote Start ---
--- Quote End ---
yes, you can ignore the warning. If you really wwant to get rid of the warning you could use the output of the FF ( used as clock) as an enable signal of the other FF.
--- Quote Start ---
--- Quote End ---
thank you very much&#65292;that‘s a great help for me&#12290;
--- Quote Start ---
--- Quote End ---
For a more thorough discussion of using clock enables instead of ripple or gated clocks, see http://www.alteraforum.com/forum/showthread.php?t=2388.
