21611 Discussions
how to deal with problem in flash programming
when i debgu my program in niosII ,it always info fllowing message:
# ! /bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.#
cd D:/altera/work/test_flash/Debug
# Creating .flash file for the project
$SOPC_KIT_NIOS2/bin/elf2flash --base=0x00000000 --end=0x3fffff --reset=0x0 --inp
ut=test_flash.elf --output=ext_flash.flash --boot=$SOPC_KIT_NIOS2/components/alt
era_nios2/boot_loader_cfi.srec
# Programming flash with the project
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --sidp=0x00703058 --id=2410241382 --t
imestamp=1218072956 --base=0x00000000 ext_flash.flash
There are no Nios II processors available which match the values specified.
Please check that your PLD is correctly configured, downloading a new SOF
file if necessary.
why? and i have checked my processor and matchings.but it's still so.What else i have to do? waiting online for you help.
Either proper sof/pof is not downloaded on board or there is mismatch in ptf and sof, i.e. you may have downloaded sof of one project and ptf of another project
