21611 Discussions
how to declare 2D array in package and the same i want to use
HOW TO DECLARE 2-D ARRAY FOR MEMORY IN PACKAGE.
THE SAME VARIABLE I WANT TO USE IN OTHER PLACE WHERE I AM CALLING THAT PACKAGE.
library ieee;
use ieee.std_logic_1164.all;
package constant_package is
constant DATA_WIDTH : integer;
constant ADDR_WIDTH : integer;
subtype word_t is std_logic_vector ((DATA_WIDTH-1) downto 0);
type memory_t is array (2**ADDR_WIDTH-1 downto 0) of word_t;
end constant_package;
package body constant_package is
constant DATA_WIDTH : integer := 8;
constant ADDR_WIDTH : integer:=8;
THIS IS WHAT MY CODE IS IT OKK???
It is ok. You can declare your type as follows for more simplicity.
type memory_t is array (2**ADDR_WIDTH-1 downto 0) of td_logic_vector ((DATA_WIDTH-1) downto 0);
use your package in other files. You can even define port types as memory_t (Beauty of VHDL)!
