Programmable Devices
21611 Discussions
how to infer out of module to be register
hello
i want to know how can i make output of the module to be registers (not combinational logic) ?
You just need to assign the signal in a edge triggered process, instead of making a continuos assignment.
For example, in Verilog
module my_module(
input wire clk,
input wire rx,
output wire tx1
output reg tx2
output reg tx3
assign tx1 = !rx;
always @ (*) tx2 <= !rx;
always @ posedge (clk) tx3 <= !rx;
endmodule
In VHDL
entity my_module is
port(
clk : in std_logic;
rx : in std_logic;
tx1 : out std_logic;
tx3 : out std_logic;
end my_module;
architecture rtl of my_module is
begin
tx1 <= not rx;
process (clk)
begin
if clk'event and clk = '1' then
tx3 <= not rx;
end if;
end process;
end rtl;
tx1 and tx2 will be just combinational logic, while tx3 will be registered
i am using vhdl ... can you give me example of vhdl
will register be the output of this 7 segment transofrmer ?
library ieee; use ieee.std_logic_1164.all ; use ieee.std_logic_arith.all; entity decoder7seg is port (DIGIT : in std_logic_vector(3 downto 0); SEG : out std_logic_vector(6 downto 0) ); end entity decoder7seg; architecture decoder7seg_a of decoder7seg is begin --decode : process DIGIT is SEG <= "0111111" when DIGIT="0000" else -- 0 "0000110" when DIGIT="0001" else -- 1 "1011011" when DIGIT="0010" else -- 2 "1001111" when DIGIT="0011" else -- 3library ieee; "1100110" when DIGIT="0100" else -- 4 "1101101" when DIGIT="0101" else -- 5 "1111101" when DIGIT="0110" else -- 6 "0000111" when DIGIT="0111" else -- 7 "1111111" when DIGIT="1000" else -- 8 "1101111" when DIGIT="1001" else -- 9 "1110111" when DIGIT="1010" else -- A "1111100" when DIGIT="1011" else -- b "0111001" when DIGIT="1100" else -- C "1011110" when DIGIT="1101" else -- d "1111001" when DIGIT="1110" else -- E "1110001" when DIGIT="1111" else -- F "0000000"; end architecture decoder7seg_a;
