hello
i want to know how can i make output of the module to be registers (not combinational logic) ?Link Copied
You just need to assign the signal in a edge triggered process, instead of making a continuos assignment.
For example, in Verilog module my_module( input wire clk, input wire rx, output wire tx1 output reg tx2 output reg tx3 ); assign tx1 = !rx; always @ (*) tx2 <= !rx; always @ posedge (clk) tx3 <= !rx; endmodule In VHDL entity my_module is port( clk : in std_logic; rx : in std_logic; tx1 : out std_logic; tx3 : out std_logic; end my_module; architecture rtl of my_module is begin tx1 <= not rx; process (clk) begin if clk'event and clk = '1' then tx3 <= not rx; end if; end process; end rtl; tx1 and tx2 will be just combinational logic, while tx3 will be registered- Mark as New
i am using vhdl ... can you give me example of vhdl
will register be the output of this 7 segment transofrmer ?
library ieee;
use ieee.std_logic_1164.all ;
use ieee.std_logic_arith.all;
entity decoder7seg is
port (DIGIT : in std_logic_vector(3 downto 0);
SEG : out std_logic_vector(6 downto 0) );
end entity decoder7seg;
architecture decoder7seg_a of decoder7seg is
begin
--decode : process DIGIT is
SEG <= "0111111" when DIGIT="0000" else -- 0
"0000110" when DIGIT="0001" else -- 1
"1011011" when DIGIT="0010" else -- 2
"1001111" when DIGIT="0011" else -- 3library ieee;
"1100110" when DIGIT="0100" else -- 4
"1101101" when DIGIT="0101" else -- 5
"1111101" when DIGIT="0110" else -- 6
"0000111" when DIGIT="0111" else -- 7
"1111111" when DIGIT="1000" else -- 8
"1101111" when DIGIT="1001" else -- 9
"1110111" when DIGIT="1010" else -- A
"1111100" when DIGIT="1011" else -- b
"0111001" when DIGIT="1100" else -- C
"1011110" when DIGIT="1101" else -- d
"1111001" when DIGIT="1110" else -- E
"1110001" when DIGIT="1111" else -- F
"0000000";
end architecture decoder7seg_a;
