Programmable Devices
21602 Discussions
how to "cut" a vector...
hi guys, i have small question.
you see i got this project and i need to build this unit , which receives "packages" in serial communication mode (also i need to know how to do it for parallel communication mode ,for the final exam). the package structure is like that : first 3 bits are address, next 3 bits are number of "data" received , and the last 8 bits are the "data".
now everything comes in one "package" . the question is how can i divide the vector into : 3,3, 8 ? and save only the last 8 bits into a fifo component ?
thanks in advance
You don't tell your what's your HDL entry method. Each language has simple constructs to access array slices, it's also easy in schematic entry.
i need it in VHDL. which and the vector is (0 to 14).
for example:
a(1 to 5) <= b(3 to 8);
The number of bits doesn't fit your example...
The last 8 bit's can be accessed like
data <= allvector(7 to 14);
The expression is called an array slice in VHDL terminology.
wait let me understand , if i got : data_in : in std_logic_vector( 7 downto 0) and i want to slice it to 5, and 3 : so i need to write : data1<=allvector(7 downto 3) and data2<=allvector( 2 downto 0 ) ?
p.s.
FvM , its suppose to be ( 0 to 13) , right ?
Yes, the bit order of your input vector may be different, however. With numeric data, a descending data direction is usual, as you wrote above for data_in. It's more clear, if you use the same direction for all involved signals, e.g. all_vector(13 downto 0). Serial data streams that are shifted in can still be LSB or MSB first, so it's best to specify clearly the bit allocation of each sub vectors. I would expect this as a standard:
address <= all_vector(13 downto 11); datanum <= all_vector(10 downto 8); data <= all_vector(7 downto 0);
thanks guys , and the last question how do i add them all after i finish doing some operations on them , do i use the "&" sign or the "+" sign ?
like :
data :out std_logic_vector ( 13 downto 0 );
data<= address (13 downto 11) & datanum (10 downto 8) & (7 downto 0);
"&" is the correct array concatenation operator.
