21592 Discussions
how to read data from the SDRAM to the FPGA
Hello dear developers, buy a DE2 development board for a project. and need to read 960 bits from SDRAM to the FPGA in parallel, but I have not found a way to do this, please if anyone can help thank you.
Greetings from Colombia.
The data bus isn't 960 bits wide, so you'll have to split it in several reads and combine the results in a big vector.
Are you planning to use SOPC builder?
This is a test
--- Quote Start ---
--- Quote End ---
Thanks for your answer!!!!, I think using SIGNALTAP to debug and verify the operation of the algorithm.
