- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Hi ,
I now directly control the function of emac through hps.
So the external PHY is directly connected to the I/O pin of hps, as shown in figure.
However, the speed of the ethernet is limited to less than 100Mbps due to the large image data to be transmitted.
So I want to replace the function of image transmission through FPGA(and keep ethernet command control in hps), as shown in the figure below.
And the question I want to ask is:
1.Is there any way to allow FPGA to control the I/O of HPS without changing the PCB layout?
2.If this method can be achieved, will his speed be limited?
Thank you.
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Yes you can route to FPGA, though the speed limitation is always be affected and varied by designs itself.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Do you have further questions?
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
