21615 Discussions
include path problem in nios 9.1
Hi
I'm new to nios. i meet a weird problem to me.
I create a new project hello_world0. and add a inc folder uder it.
then i add a new file test.h in this inc folder. and include it in the hello_world.c. I also add the path to project properties.
But when I build the project, it show me that he can't find test.h, does someone knows why ?
thank you very much.
nios9 IDE sucks!!!!
add include path is not working, it should be add in C/C++ build/tool setting/Nios compiler/General.
I had some trouble with the IDE and include paths too. If you use a relative path from the project folder to the include file (#include "inc/test.h") it should work.
