hello everyone,
I need help here.Below is my vhdl code: LIBRARY ieee; USE ieee.ALL; ENTITY haar IS PORT ( clock : IN bit; clk : IN bit; -- Inputs in1 : IN integer RANGE -127 TO 127; in2 : IN integer RANGE -127 TO 127; in3 : IN integer RANGE -127 TO 127; in4 : IN integer RANGE -127 TO 127; in5 : IN integer RANGE -127 TO 127; in6 : IN integer RANGE -127 TO 127; in7 : IN integer RANGE -127 TO 127; in8 : IN integer RANGE -127 TO 127; --Outputs out1 : OUT integer RANGE -127 TO 127; out2 : OUT integer RANGE -127 TO 127; out3 : OUT integer RANGE -127 TO 127; out4 : OUT integer RANGE -127 TO 127; out5 : OUT integer RANGE -127 TO 127; out6 : OUT integer RANGE -127 TO 127; out7 : OUT integer RANGE -127 TO 127; out8 : OUT integer RANGE -127 TO 127 ); END haar; ARCHITECTURE haar OF haar IS begin PROCESS(clk) BEGIN IF clk'EVENT AND clk = '1' THEN output <= input; END IF; END PROCESS; END haar; My question is why when i create the waveform file for the code, the pins is not same as the expected pins? I get the input pins like below: in1[0] in1[1] in1[2]....in1[7] But, that is not i want.Suppose the input is like: in1, in2, in3,....in8. Can anyone help me solve this problem?.Link Copied
Each of your ports translates to 8 bits in Hardware terms.
I wonder what output <= input; means as these names are not declared or did you just say it for short...- Mark as New
the code above is for short..Actually i obtain the based on the pipelined architecture that i has been designed.It consist of 3 stage and include 3 basic component.I try to troubleshoot the coding by simulate stage by stage,but the problem occurs is same..why?
Thanks for reply.- Mark as New
You don't have any problem thus far. You are asking in1 to be range -127 ~ 127 i.e. 8 bits. so is in2 and so on...
Sorry, i don't understand what u said..It is mean that the input pins i get;
in1[0], in1[1], in1[2]....in1[7] is correct?- Mark as New
--- Quote Start --- I get the input pins like below: in1[0] in1[1] in1[2]....in1[7][/QUOte]
where do you get like this?
I get the pins at the vector waveform file..in the node finder.
--- Quote Start --- I get the pins at the vector waveform file..in the node finder. --- Quote End --- I see, but I don't know why. You can rearrange them by using the grouping feature.
Thanks FvM..can i ask one question, what actually the function of buffer in vhdl code?
