链接已复制
i am new in this field. i have seen the intel cyclone FPGA kit they have use switching regulator the regulator they have used are obsolete now i want to use linear regulator can you recommend me which linear regulator i can use???i have seen the document they mention in that we can use linear regulator for VCCIO and VCCA but not mentioned for VCCINT and VCC_PLL .Can you please guide me how i can use early power estimator
Please check following links from the Pin Connection Guidelines for Max 10.
This one will provide you the basic recommendation for the board connection.
Following one provide some examples as well:
Power Supply Sharing Guidelines (intel.com)
Checking the Max 10 development kits resources will also help.
For the EPE, would recommend you to go through the following link:
1. Overview of the Early Power Estimator for Intel® Cyclone® 10 LP
Key to using the EPE efficiently is to provide as much accurate information about your FPGA design and the board details as possible.
