- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
i need to interface altera's fft ip core with nios processor.fft core is implementing 16k fft.To interface this fft core with scatter gather dma i made following 'manipulation' of fft core.
what i have done is grouping imaginary and real parts and exponent output is made 32 bits with eop, sop......... for it is derived seperately. library IEEE; use IEEE.std_logic_1164.all; use IEEE.numeric_std.all; library altera; use altera.altera_primitives_components.all; entity newfft is PORT ( clk : IN STD_LOGIC; reset_n : IN STD_LOGIC; inverse : IN STD_LOGIC; sink_valid : IN STD_LOGIC; sink_sop : IN STD_LOGIC; sink_eop : IN STD_LOGIC; sink_data : IN STD_LOGIC_VECTOR (31 DOWNTO 0); sink_error : IN STD_LOGIC_VECTOR (1 DOWNTO 0); source_ready1 : IN STD_LOGIC; sink_ready1 : OUT STD_LOGIC; sink_ready2: OUT STD_LOGIC; source_error1 : OUT STD_LOGIC_VECTOR (1 DOWNTO 0); source_error2 : OUT STD_LOGIC_VECTOR (1 DOWNTO 0); source_sop1 : OUT STD_LOGIC; source_sop2 : OUT STD_LOGIC; source_eop1 : OUT STD_LOGIC; source_eop2 : OUT STD_LOGIC; source_valid1 : OUT STD_LOGIC; source_valid2 : OUT STD_LOGIC; source_data : OUT STD_LOGIC_VECTOR (31 DOWNTO 0); source_data2 : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ); end newfft; architecture trial of newfft is signal s1,s2,s4,s5:std_logic_vector(15 downto 0); signal s7:std_logic_vector(31 downto 0); signal s3:std_logic_vector(5 downto 0); signal data1,data2,data3,data4,data5,data6:std_logic; signal data7:std_logic_vector(1 downto 0); component fftcore IS PORT ( clk : IN STD_LOGIC; reset_n : IN STD_LOGIC; inverse : IN STD_LOGIC; sink_valid : IN STD_LOGIC; sink_sop : IN STD_LOGIC; sink_eop : IN STD_LOGIC; sink_real : IN STD_LOGIC_VECTOR (15 DOWNTO 0); sink_imag : IN STD_LOGIC_VECTOR (15 DOWNTO 0); sink_error : IN STD_LOGIC_VECTOR (1 DOWNTO 0); source_ready : IN STD_LOGIC; sink_ready : OUT STD_LOGIC; source_error : OUT STD_LOGIC_VECTOR (1 DOWNTO 0); source_sop : OUT STD_LOGIC; source_eop : OUT STD_LOGIC; source_valid : OUT STD_LOGIC; source_exp : OUT STD_LOGIC_VECTOR (5 DOWNTO 0); source_real : OUT STD_LOGIC_VECTOR (15 DOWNTO 0); source_imag : OUT STD_LOGIC_VECTOR (15 DOWNTO 0) ); END component fftcore; begin fft1:fftagain port map(clk,reset_n,inverse,sink_valid,sink_sop,sink_eop,sink_data(31 downto 16),sink_data(15 downto 0),sink_error,source_ready1,data1,data7,data2,data3,data4,s3,source_data(31 downto 16),source_data(15 downto 0)); source_sop1<=data2; source_sop2<=data2; sink_ready1<=data1; sink_ready2<=data1; source_error1<=data7; source_error2<=data7; source_eop1<=data3; source_eop2<=data3; source_valid1<=data4; source_valid2<=data4; source_data2(31 downto 6)<=(others=>'0'); source_data2(5 downto 0)<=s3; end trial; but now the problem is sgdma has an empty signal of 2 bits but fft core has got none.what to do now??? Is there any other method??- 태그:
- fft
링크가 복사됨
3 응답
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Since in your other posts you've already said you've read all the documentation and don't want to be told to read it, I feel bad for saying it, but you need to read the documentation.
In particular, see: http://www.altera.com/literature/manual/mnl_avalon_spec.pdf (Section 5.3, at least) http://www.altera.com/literature/hb/qts/qsys_interconnect.pdf (pages 9-24 to 9-28 for starters). Good luck!- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I'm not sure, I don't have the v9 tools installed any longer since they are four years old. You could probably check the documentation that you have already read again and maybe it will say?
If it doesn't, then the tool you might be using might be called "SOPC Builder" and it's (very similar) documentation is here, and you should re-read it again: http://www.altera.com/literature/ug/ug_sopc_builder.pdf (pages 3-3 to 3-5 for starters) Good luck!
