21596 Discussions
jtag user0/user1 registers in VHDL logic
How do I define the jtag user0/user1 registers in my vhdl code on CycloneIV?
What are the signal names are for at least tdi/tdo and the 'shiftdr' state, for use from VHDL?
In other words, what is Altera's version of Xilinx's 'bscan' component?
I have searched, but only found references to 'virtual jtag megawizards', which (as far as I understand)
build a huge edifice on user0/user1, when I just want to use user0/user1 'raw'.
The Altera equivalent of the BSCAN component is the SLD_Virtual_JTAG component. You don't need to explicitly use USER0/USER1 instructions like with BSCAN. Altera has created an infrustructure where multiple JTAG components can share a common USER0/USER1 instruction register. Take a look at the JTAG analysis on this page:
https://www.ovro.caltech.edu/~dwh/correlator/cobra_docs.html
The SLD JTAG is analyzed in
https://www.ovro.caltech.edu/~dwh/correlator/pdf/vjtag.pdf
But it turns out that the JTAG-to-Avalon-MM bridge is pretty generically useful, so if you use that, along with Qsysa, you can pretty much build anything you like.
Cheers.
Dave
