Programmable Devices
load image
Bonjour,
Je veux charger une image sur une FPGA cyclone III.
Existe-t-il un moyen de faire ça?
merci d'avance :)
hi
i want to load an image in FPGA.
How i can do it?
Hello Rose,
You might convert your image into a hex file, and instantiate a memory with that hex file.
I would generate a 32bit memory, where each slot is used for one pixel (Y-Cb-Cr channels-each 8 bits (24 bits in total), 8 bits redundant).
I hope this helps.
Cheers.
