21615 Discussions
look at SPI-to-UART on Tektronix scope
Hello people in here,
I have problem to show the uart on Tektronix scope. I can see the output on SignalTap II, but I want to see on scope. My data output is 8 bits from SPI slave to UART. And how do I show that 8 bits on scope in hex value or one line.
Thank you,
Sean
Depending on your tek scope you probably need the Embedded Serial Triggering and Analysis Module. or Computer Serial Triggering and Analysis Module.
http://www.tek.com/datasheet/product-software/serial-triggering-and-analysis-application-modules%20
shows some of the modules available.
