Hi, I have a question. now there are 3 vector connect with AND gate like this:
C(3)<= A(4) and B(3) C(2)<= A(4)and A(3)and B(2) C(1)<= A(4)and A(3)andA(2)and B(1) C(0)<= A(4)and A(3)andA(2)andA(1)B(0) How can I use loop to describe it?Link Copied
Do you want to write generic code or do you simply want to use a
loop construct on the actual code you've posted? Using a loop construct on your actual code will make it worse imho.- Mark as New
with generic code, like:
C(n-1)<= A(n) and B(n-1) C(n-2)<= A(n)and A(n-1)and B(n-2) ...... C(0)<= A(n)and A(n-1)......and A(1)B(0). upstair is a example for n=4- Mark as New
--- Quote Start --- Do you want to write generic code or do you simply want to use a loop construct on the actual code you've posted? Using a loop construct on your actual code will make it worse imho. --- Quote End --- with generic code, like: C(n-1)<= A(n) and B(n-1) C(n-2)<= A(n)and A(n-1)and B(n-2) ...... C(0)<= A(n)and A(n-1)......and A(1)B(0). upstair is a example for n=4
--- Quote Start --- with generic code, like: C(n-1)<= A(n) and B(n-1) C(n-2)<= A(n)and A(n-1)and B(n-2) ...... C(0)<= A(n)and A(n-1)......and A(1)B(0). upstair is a example for n=4 --- Quote End --- BTW: What does A(1)B(1) mean?
Try something like that
for i in 0 to n - 1 loop
for j in i + 2 to n loop
a_res := a(j) and a(j - 1);
end loop;
c(i) <= a_res and b(i);
end loop;
But be aware that it's untested code. You've to verify it. :) edit: That's definitely not it! :( But I think you've to use nested loops...
I think something like that would do the trickfor i in 0 to n - 1 loop
a_res := a(n);
for j in i + 1 to n - 1 loop
a_res := a_res and a(j);
end loop;
end loop;
Yes the nested loops ides is the right one, you just need to initialize the variable and use it recursively in the inside loop. Don't forget to declare the variable in the process.
