21611 Discussions
loop must end 5000 iteration error
i have a verilog program ,while compiling it gives error like loop must end in 5000 iteration on line 36
module memory
(mem_dump,
ntb_encoder,
enable_m,
nr_w_m,
addr_m,
din_m,
dout_m);
input mem_dump;
input ntb_encoder;
input enable_m;
input nr_w_m;
input [16:0] addr_m;
input [7:0] din_m;
output [7:0]dout_m;
reg [7:0] mem[0:131071];
reg [7:0] dout_m;
reg mem_dump_bit;
integer i;
integer p;
integer k;
integer handle1;
integer handle2;
integer handle3;
integer j;
integer l;
initial
begin: ram_initialization_block
begin
p=131072;
for (i=0; i<p; i=i+1)
mem[i]= 8'd0;
$readmemh("ref_frame.txt", mem,0,25343);
$readmemh("cur_frame.txt", mem,25344,50687);
mem_dump_bit = 1'b0;
end
end
always@(ntb_encoder or nr_w_m or enable_m or din_m or addr_m or mem_dump)
begin: memory_block
if (enable_m == 1'b0)
dout_m = 8'bZZZZZZZZ;
else if (enable_m == 1'b1 && nr_w_m == 1'b0 && ntb_encoder == 1'b1)
dout_m = mem[addr_m];
else if (enable_m == 1'b1 && nr_w_m == 1'b1 && ntb_encoder == 1'b1 && addr_m >= 50688)
mem[addr_m] = din_m;
else
if (mem_dump == 1'b1 && mem_dump_bit == 1'b0)
begin
handle1=$fopen("vertical_mv_bitstream.txt");
for (k=52272; k<53856; k=k+1)
$fdisplay(handle1,"%d",mem[k]);
$fclose(handle1);
handle2=$fopen("horizontal_mv_bitstream.txt");
for (j=50688; j<52272; j=j+1)
$fdisplay(handle2,"%d",mem[j]);
$fclose(handle2);
handle3=$fopen("res_bitstream.txt");
for (l=53856; l<79200; l=l+1)
$fdisplay(handle3,"%d",mem[l]);
$fclose(handle3);
end
end
endmodule
please any one help
--- Quote Start ---
module memory
(mem_dump,
ntb_encoder,
enable_m,
nr_w_m,
addr_m,
din_m,
dout_m);
input mem_dump;
input ntb_encoder;
input enable_m;
input nr_w_m;
input [7:0] din_m;
output [7:0]dout_m;
reg [7:0] dout_m;
reg mem_dump_bit;
integer i;
integer p;
integer k;
integer handle1;
integer handle2;
integer handle3;
integer j;
integer l;
initial
begin
p=131072;
mem[i]= 8'd0;
end
end
begin: memory_block
else
begin
$fclose(handle1);
$fclose(handle2);
$fclose(handle3);
end
end
endmodule
please any one help
--- Quote End ---
which tool do you use ? Is a simulation your intention ?
Kind regards
GPK
--- Quote Start ---
Kind regards
GPK
--- Quote End ---
in case of Quartus the default limit for constant verilog loops is 5000. You can change the setting under :
Assignment -> Settings -> Analysis&Synthesis -> More Settings ... -> Iteration limit for constant Verilog loops
With your large loops I would expect a long runtime for "Analysis & Synthesis".
Kind regards
GPK
--- Quote Start ---
--- Quote End ---
THANK YOU!! This is exactly what I needed!
What I find curious is that the default iteration limit of 5000 only allows you to loop 4999 times rather than 5000 times like you would think. I had to loop exactly 5000 times so I had to set the limit to 5001. Seems like a simple fence-post programming error in the Quartus tool. Not a big deal though. I'm just glad they let you change the limit. :)
To those of you looking for this option in quartus 15.1,
It has moved to Assignments / Settings / Compiler settings / Advanced Settings [= a button in the frame] / iteration limit for constant verilog loops.
Johi.
