21602 Discussions
max10 internal memory write protection
nicoh
hi,
I'm using the max10 FPGA (with quartus prime lite 18.1)
how can I check if it's configured to internal memory write protection (and change it if not)?
NurAiman_M_Intel
You can refer to MAX 10 configuration userguide;
https://www.intel.com/programmable/technical-pdfs/683865.pdf
Aiman
nicoh
obviously it's the first thing I checked... not helpful
NurAiman_M_Intel
Sorry about that. You can refer to MAX 10 UFM userguide. It mention on how to enable and disable the write protect on page 19.
https://www.intel.com/content/dam/support/jp/ja/programmable/support-resources/bulk-container/pdfs/literature/hb/max-10/ug-m10-ufm.pdf
"You have to enable back the write protection mode when the program operation completes. Write 1 into the write protection register for the corresponding sector through the Avalon-MM control interface."
Aiman
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
