21611 Discussions
memory assignment on a ddr-sdram
I have a C program which works but I would like to have a buffer stored on the ddr sdram. Thus, I used the function "__attribute__"
The problem is that I would like my buffer size to be 640*480.
unsigned int buffer_video [640*480] __attribute__ ((section (".ddr_sdram")));
When I do a 64*48 buffer, it works but for example, when doing a 90*50 buffer, I have the error :
Verifying 00010000 ( 0%)
Verifying 00013C2C (45%)
Verify failed between address 0x13C2C and 0x1827B
Leaving target processor paused
Does someone have an idea ?
Myriam
To precise my problem, it seems there are 3 steps :
1. Little size buffer : it is working
2. Middle size buffer : "verify failed... leaving target processor failed"
3. Big size buffer : memory is full
It does the same with my ssram.
If you have an idea, please help me !
Myriam
