21611 Discussions
missing files in quartus\libraries\megafunctions
Chris2000
I have a QSYS module from a previous design for a Cyclone 5 that was successfully implemented using Quartus Std 18.1.
I am using this module on a new Arria 10 design using Quartus Pro 20.2.
I get this error when I compile the design in Quartus 20.2:
   Error(287062): Can't open AHDL Include File stratixgx_lvds_receiver.inc
The file is present in the Quartus 18 directory:
   C:\intelFPGA\18.1\quartus\libraries\megafunctions\stratixgx_lvds_receiver.inc
   C:\intelFPGA\18.1\quartus\libraries\megafunctions\xml_info\stratixgx_lvds_receiver_info.xml
   C:\intelFPGA\18.1\quartus\libraries\megafunctions\stratixgx_lvds_transmitter.inc
   C:\intelFPGA\18.1\quartus\libraries\megafunctions\xml_info\stratixgx_lvds_transmitter_info.xml
But it is not present in the Quartus 20 directory.  However the corresponding transmitter file is present.  Why is only the receiver file missing?  I could try to copy it over from Quartus 18, but I would like a solution that doesn't break with the next Quartus update.
   C:\intelFPGA_pro\20.2\quartus\libraries\megafunctions\stratixgx_lvds_transmitter.inc
   C:\intelFPGA_pro\20.2\quartus\libraries\megafunctions\xml_info\stratixgx_lvds_transmitter_info.xml
sstrell
My guess would be that Cyclone V used the old Stratix GX IP and since Cyclone V is not supported in the Pro edition, that would be why you're seeing an issue (though I don't know why only the receiver files would be missing).  Since this is a Platform Designer system (not called Qsys anymore), just delete the component from the system design and add in a serdes for Arria 10 from the IP Catalog.
RichardTanSY_Altera
Hi, do you able to solve your issue based on Strell's suggestion?
