20754 Discussions
modelsim: how to use parameter and error faced
It is pretty fine when i use QII to compile my design. However, when i use modelsim-starter edition, a lots of error popping out.
Error:
Identifier must be declared with a port mode: d.
My submodule:
module fir_comb_RAM1(clk, reset, ena, valid, d, count, q, RAM_coeff, mult_result);
input clk;
input reset;
input ena;
input valid;
input [count_w-1:0] count;
input signed [signal_mag_w-1:fp_w] d;
input signed [signal_mag_w-1:fp_w] q ;
input signed [coeff_w-1:fp_w] RAM_coeff;
I have no idea why modelsim ask me to declare d as a port since i already declare it as input
Besides, how to use parameter in modelsim? In Qii, i use it as below:
e.g1:
parameter count_w = 4;
It gives me an error undefined variable of count_w;
e.g2:
if (count_64 < (max_coeff+1))...
It gives me an error undefined variable of max_coeff;
Any idea?
thanks
The 2 errors caused by 1 problem only. The placement of parameter should be put on top after the entity. what a silly mistake..
thanks
