21610 Discussions
multiple clock domain instruction
Hi, guys,
I am now studying the document named "building systems with multiple clock domains" which is in Quartux II Handbook, Volume 4.
in page 11-8, it says that I need to find something inside the file standard.bdf, however, I spend hours finding the standard.bdf file but couldn't find it in my computer. I am pretty sure I did correctly in the previous steps...
Anybody knows where the file is? I am kinda rookie to the altera software for now..
thanks a lot
standard is the design name for which ever device you are targeting, and the bdf should be in that directory. did you check:
<Nios II EDS install path>\examples\<verilog or vhdl>\<board
version>\standard
hello
Maybe this thread is useful for you
http://www.alteraforum.com/forum/showthread.php?t=6627&highlight=dabg
Chao
DABG
--- Quote Start ---
version>\standard
--- Quote End ---
thanks for the reply. Exactly, there is such a directory! I thought the bdf file might be there after I generated the updated system using SOPC builder; however, it is not there!! :confused:
where else can i check? thank you
--- Quote Start ---
hello
Chao
DABG
--- Quote End ---
Hi, thanks for the link.. sorry that I didn't see the info abt bdf file there. Where could i find it or download it or need to generate or just draw it myself (quite impossible)?
--- Quote Start ---
version>\standard
--- Quote End ---
and there is a bsf file only...
please help~~ =(
i don't see any bdf files either. the manual must be out dated.
you will have to create the bdf or work with the HDL file instead.
I am not sure if I understood your question, but for manage multiple clock domain you can use a double clock fifo.
You can generate this fifo using the MEGAWIZARD PLUG IN MANAGER.
tools>>megawizard plug in manager>>create...>>memory_compiler>>fifo
Good luck.
thank you. maybe you are right, but the v code seems quite complicated
ok. let me try, thank you =)
