21611 Discussions
need a cross match for 5CEBA2F23C8N ASAP
PROTECHBuyer
no stock to be found and need a cross/alternative part with exact specs
Alberto_R_Intel
PROTECHBuyer, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate support on this matter, I just moved your thread to the proper department so they can further assist you with this topic as soon as possible.
Albert R.
EngWei_O_Intel
Hi there
You can check on Figure 7 of doc below for valid device migration.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-v/cv_51001.pdf
If the device on the migration path is not available, you will need to make some changes to your existing design.
Eng Wei
