The screenshot is too small to see anything.
--- Quote Start --- The screenshot is too small to see anything. --- Quote End --- thanks for reply in the first picture show that condition from R1: Reset Wait to R0: Reset Start reset with the condition " arbTimer >=resetDuration + RESET_WAIT " when I input the " + " in there, Quartus show another window which is send pic said " illegal verilog syntax found at character position 28, near + ". How do I fix that problem?
So find the illegal Verilog syntax near position 28 and remove it.
Don't ask me what it is or on what line - only you have the Verilog code and my crystal ball is broken.- Mark as New
you need to convert expression like "arbTimer >=resetDuration + RESET_WAIT" to boolean equivalent like "cond_input = (arbTimer >=resetDuration + RESET_WAIT) "
and use cond_input in stateflow diagramm. I advise you to replace complex condition with simple one, and later in code you can insert how to calculate it .- Mark as New
thanks for you help
