21618 Discussions
nios II -sometime booting sometime not
Dear Friends,
I have nios II system (STRATIX II EP2S60F1020C5)with,
1. SDRAM
2. ext Flash
3. Nios II
4. LED
Reset : CFI flash
Exepction: SDRAM
Software library setup, .ro, program. , .txt - everything point to - SDRAM
This system setup is works fine, when trigger with nios II IDE, and when board reset and cpu reset,
but real problem comes when i done with bootloader, the system sometimes boots out of 10 try 6 try success, another 4 try fails, and cpu reset sometimes success then fails,
i dont know what is the problem , please help me
regards
baba
Check if the max frequency of your system after synthesis/fitter is more important than the running frequency of your system on the board (usually 85mhz).
Are you using JTAG UART? Try using a simple program with boot loader that simply blinks LEDs and does not use JTAG UART.
