21611 Discussions
nios2-build-project command line
I've got some problems about the "nios2-build-project" command line :
when i type this command, i've got the following warnings which appear on my screen :
!ENTRY org.eclipse.osgi 4 0 2009-10-08 09:51:00.906
!MESSAGE Error reading configuration: C:\altera\90\nios2eds\bin\eclipse\configuration\org.eclipse.osgi\.manager\.fileTableLock (Access is denied)
!STACK 0
java.io.FileNotFoundException: C:\altera\90\nios2eds\bin\eclipse\configuration\org.eclipse.osgi\.manager\.fileTableLock (Access is denied)
at java.io.RandomAccessFile.open(Native Method)
at java.io.RandomAccessFile.<init>(Unknown Source)
at org.eclipse.core.runtime.internal.adaptor.Locker_JavaNio.lock(Locker_JavaNio.java:30)
at org.eclipse.osgi.storagemanager.StorageManager.lock(StorageManager.java:387)
at org.eclipse.osgi.storagemanager.StorageManager.open(StorageManager.java:694)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.initFileManager(BaseStorage.java:152)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.initialize(BaseStorage.java:129)
at org.eclipse.osgi.baseadaptor.BaseAdaptor.initializeStorage(BaseAdaptor.java:124)
at org.eclipse.osgi.framework.internal.core.Framework.initialize(Framework.java:138)
at org.eclipse.osgi.framework.internal.core.Framework.<init>(Framework.java:112)
at org.eclipse.osgi.framework.internal.core.OSGi.createFramework(OSGi.java:90)
at org.eclipse.osgi.framework.internal.core.OSGi.<init>(OSGi.java:31)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:286)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:173)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
And it is impossible to use this command when :
i change to soft directory
i type : nios2-build-project --projectName=tb_XXX
i get :
warning message from eclipse
and nothing has occured
Is anybody can help me ?
