21615 Discussions
nios2 design help
hey guys can u tel me why .text file wil so big like 16kb-20kb n all .. is there any way i can change settings to make it small..i dont want any special features in my nios 2 design.. im expecting its size to be small. any heads up... pls
try thsese setting on System Library Property
check:
Program never exits
Reduced device drivers
Small C library
uncheck:
Support C++
Clean exit
also smaller Max file descriptors like 32 -> 4 or so.
have you tried that?
i have tried wit reduced drivers and small c. bu stil no great difference.. i wil try others..
stil how to make it use only criticle drivers.
how do i know wat driver it should use..
and wat r optimal stack size for interrupts n exception(r they needed).. im not using any interrupt from my code perspective.
thanks for reply.... expecting more help..pls
Don't ask the same question multiple times please.
Try to turn on the compiler "optimize for size" option (-Os)
